Finally My Strano Drop!
OP, car looks a lot better.
yeah i did them myself...actually it took me all day to to the fronts cause i had to get the top shock bolt broke loose at a shop....theres no way i could have done it without having air tools, they zipped it right off! and also im so **** about ****...that i cleaned everything when i took it apart and repainted everything black....change the sway bar bushings since i was there anyways....the biggest pain in the *** was compressing the springs....had to using an impact drill on the bolt.....way! to much tension for me to do it.
other than that....everything was pretty simple. rears are a breeze!
daily driving i dont see any combo going bad.....not as bad as driving around on 5, 7, 9,10 year old stock shocks.
you want something like the koni's then spend the money on them. you cant afford that right now...then do the next best thing and get the billy's.
