What kind of low beams are these??
Can anyone tell me what these bulbs are/model number so I can buy some proper xenon ones. Thanks a bunch
Anyone know a reputable site/manufacturer where I could purchase some decent quality bulbs? Also I want the best longevity and look, should I do actuall HID kits with a ballast or just use bulbs like PIAA or Phillips?
Or get a Catz Zeta kit to boost the halogen output. It feeds the bulbs 15+V instead of the stock 13.8, but that means more heat and shorter life.
Are these projectors? If so, a good alternative is an HID kit. Stick with 4300K or 5000K for the best output. The higher #K bulbs are bluer/purpler but also dimmer.
An H1 halogen bulb is often rated at 1550 lumen,
A good 4300K HID setup is often rated at 3200 lumen.
(Many cheap ebay HID kits are lower than that, but still much higher than Halogen)
The brightest normal Halogen bulb you can get is a H9 which is 2100 lumen. There is no way it will fit in place of a H1 though because it is shaped quite differently.
The problem with higher K bulbs is not just the drop in brightness, but also the color of the light is less useful. A crap ebay HID kit at 8000K will still be brighter than Halogen, but only by a little and the color will be straining on the eyes so its worse than sticking with Halogen. 10000K & 12000K are just horrible. Of course, there will be people that disagree because they "love the color", but its physics and biology that they are fighting a loosing battle with.
Also, Halogen projectors are designed differently than HID projectors and spread the light differently. However some Halogen projectors handle HID OK, some don't (the cheap H3 projectors on ebay don't, but they suck with a Halogen bulb too.). Some H1 projectors on ebay are passable, but pale in comparison to a true HID projector.
In short, HID kits on ebay cost about the same as good Halogen bulbs, so its worth a shot to try.
Some others on here have bought from some ebay sellers. I don't remember their names, but you should be able to find them by searching on here.
The Retrofit Source has some good stuff, but its more expensive than what you'll find on ebay.
Why are you looking for 5000k - 6000k range? Are you looking for a bluish tint?
I had 6000k first. Had too much bluish tint and made driving in certain weather conditions not too great. 5000k was much better.
Ever hear of this place? http://www.hidxenonlights.com/h1-hid-bulbs-c-644 or http://www.hidnation.com/h1hidkits.html
You ever have this problem with you HID's?
By the way, the car was a frozen chunk, the battery was half frozen and barely was able to start the engine, the tires were frozen to the parking deck, and it took at least 20-30 minutes before I had any sort of usable heat
HID Nation's kit seems cheap until you realize they nickel and dime you on things to bring the price back up to what others charge or more ($20 extra for a warranty, wtf, its not like they give you a better/different kit). DDM Tuning has 35 watt Digital HID kits for $45 with warranty. ($35 for non-digital 35watt, $55 for 55watt digital).
Digital HID kits are a little more efficient. Also, if you do have that issue, a relay harness should fix it.
