HELP: Trans Am Turn Signal
Old Mar 12, 2004 | 03:43 PM
DamonNC's Avatar
Default HELP: Trans Am Turn Signal
The left turn signal on my 98' Trans Am burned out. I can not figure out how to get the bulb out. I was wondering if anyone knows the best way to get the bulb out and replace it?
Old Mar 12, 2004 | 04:00 PM
WS6FirebirdTA00's Avatar
front or rear? if its the front get a 10mm and unscrew 2 under the car in front of the wheel and a flap will come down and u can get it from there. or reach in the air vents right under the signal if u have small hands. there is a clip u need to push in and then twist it right out
Old Mar 12, 2004 | 06:08 PM
DamonNC's Avatar
Thanks!
Old Mar 12, 2004 | 06:24 PM
Danny2tek's Avatar
yep I did the hand thru the air vents and its quicker
Old Mar 12, 2004 | 06:32 PM
so how close are you to charlotte?
Old Feb 23, 2005 | 08:37 PM
_HAVOC_'s Avatar
thank you, i used this method and it worked great!
