Windows Leaking Help!
Old Feb 8, 2012 | 04:07 PM
DOG-TWO's Avatar
Default Windows Leaking Help!
On my 98 Trans Am I can't go wash my car because it leaks really bad all the way around the whole window on both sides. Do I know to replace the rubber all along my windows or what?
Old Feb 8, 2012 | 05:29 PM
VIP1's Avatar
Copy & Paste Moderator
Is it the seal that has failed or did the window mechanism sag and not let the window go all the way up?
Old Feb 9, 2012 | 04:40 PM
DOG-TWO's Avatar
Well I've had the window motors replaced recently and I'm not happy with them cuz they are still slow but it also leaked before I had the new window motors.
Old Feb 9, 2012 | 09:55 PM
VIP1's Avatar
I'm talking about the frame that the motor and regulator attaches. Look at the forward edge of the window. Is it up all the way flush with the plastic triangle at the front of the door or is it slightly below that? Also, with the door panel removed, look at the mounting points for the window motor/regulator frame. See if the holes are slotted.
Old Feb 10, 2012 | 04:07 PM
DOG-TWO's Avatar
It is flush with the triangle. So does that mean I should look into the window seals? I'm hesitant towards the rubber around the window because it is very very super expensive from what I've seen!
Old Feb 10, 2012 | 06:06 PM
VIP1's Avatar
Then it may be the weather seal or the position of the T-Tops. Can you post pics? Its also possible that the rear of the window sagged. I'm just trying to eliminate having to replace the weather seal unless that is really the problem.
Old Feb 10, 2012 | 06:09 PM
Snake_Skinner's Avatar
Just how expensive is the weather seal usually?
Old Feb 10, 2012 | 07:11 PM
DOG-TWO's Avatar
I appreciate your input but I don't think you would be able to tell anything from pics. When I wash it though...water is all over the inside of the window and it drips on to the seat quite a bit. It doesn't leak anywhere around the t-top except for where it's connected to the window.
 Michael S. Palmer
Old Feb 10, 2012 | 07:12 PM
DOG-TWO's Avatar
It's almost 300 for one side I think.
Old Feb 10, 2012 | 07:23 PM
__Z__'s Avatar
just go rip one off a junk yard car... probably run ya like 30 bucks... bring a bucket with water to make sure it doesnt leak haha
Old Feb 10, 2012 | 07:35 PM
DOG-TWO's Avatar
I'm thinkin' that's what I'm going to do lol.
Old Feb 10, 2012 | 11:07 PM
^ How many miles you got on your T/A?
Old Feb 11, 2012 | 12:51 PM
DOG-TWO's Avatar
Originally Posted by snake_skinner
^ how many miles you got on your t/a?
143,000
Old Nov 13, 2012 | 12:27 PM
Landon22's Avatar
i took rubber silicone and coated a solid layer all the way down the lip of the weather stripping where the window contacts the weather strip. the rubber silicone flexes around the window and keeps it from leaking and also reduces wind noise when driving.... saved me a ton of money but make sure you dont roll the window all the way up so it doesnt dry to the window! hope this helps!!!
Old Nov 13, 2012 | 03:19 PM
nintythreez28's Avatar
there is guide pads for the window behind the door pannell that let the window come closer or farther away from the weather stripping. id bet money its that
they can easily be adjusted
Old Nov 13, 2012 | 04:17 PM
junior98's Avatar
Do you have any pictures of where you put the silicone? Do you mean just leave the window down while it dries?
Old Nov 14, 2012 | 06:44 PM
D3VIL's Avatar
VERY interested in seeing this...
Cause I too have this leak problem!
I've also heard of specific sprays to use to make the worn seal puffy and make it come back up again? I'm sure I've booked marked it here somewhere...
All I know is that it's too expensive at a brand new price
Old Nov 14, 2012 | 07:31 PM
A3sch 98's Avatar
Just check the weather stripping... mine does it all the time. Natural deterioration from time
