6le seat install with brackets...help!!!
Old Mar 16, 2012 | 02:10 PM
silversrtman's Avatar
from what i could tell from the pictures...which are kinda bad lol....the mounting holes for the seats on the brackets are too far apart? Am i seeing that right?
Old Mar 16, 2012 | 02:11 PM
Shamson5.7's Avatar
Now looking at the slider release it shouldnt be this close to the front of the seat either. I cant even get it to rotate. There has got to be something Im doing wrong here, but I cant figure it out.
Old Mar 16, 2012 | 02:12 PM
Shamson5.7's Avatar
Yes. The sliders seem too long for the holes in the seats and the bracket's holes are too far apart from the sliders.
Old Mar 16, 2012 | 02:16 PM
maybe you got the wrong set of seats from 6LE? I know that the frame on their style seats is modified some to fit the brackets...
Old Mar 16, 2012 | 02:20 PM
Shamson5.7's Avatar
Whats odd is that if I put the bracket directly onto the bottom of the seat w.o a slider in between the holes on the seats and brackets match up fine. The sliders dont match at all.
Old Mar 16, 2012 | 04:16 PM
Shamson5.7's Avatar
Cleaned up this thread just a little. I messed around and swapped around the sliders for the driver's side seat and got everything lined up. Got it installed finally. I cant do the passenger side yet since I dont have a tool to put a notch in the sliders for that side. Its only off by a hair but enough to not let me bolt the sliders to the seats.
Old Mar 30, 2012 | 04:50 PM
STFU racing's Avatar
Im having the same problem. My sliders don't line up with the seats at all. Looks like I'm going to have to shave out maybe an 1/8 or more to make them fit.
Old Mar 31, 2012 | 10:26 AM
Amazin1's Avatar
i had all the same issues shamson. i actually had to bend my passenger side release so it could be used.
Old Apr 1, 2012 | 04:24 PM
99zMD's Avatar
I eventually got mine installed, but I had to grind the brackets and sliders to get them to match up. I also swapped the driver & passenger side release so they could be used. If the bars were facing in towards the center of the car they were flush against the bottom of the seat and couldn't be used.
Old Apr 1, 2012 | 05:56 PM
Amazin1's Avatar
all these issues sound pretty standard at the moment. maybe 6LE can get with their suppliers and see if some of these issues can be addressed. won't help us but, maybe save someone in the future the same hassles.
Old Apr 2, 2012 | 02:08 PM
My pass size had that problem. It was flush with the bottom of the seat so I placed it facing the console. Not my favorite but it works
Old Apr 2, 2012 | 03:35 PM
  #32
Shamson5.7's Avatar
I ended up putting the lever in a vice and bending it out a bit. Took a bit of muscle but it isnt flush with the seat anymore. Looking back at the install it was a bit of a pain, but Ive had a lot worse issues with installs. Very happy with the seats now.
Old Apr 2, 2012 | 03:38 PM
  #33
Shamson5.7's Avatar
Also one bracket out of the 4 sent fit perfectly and was notched out nicely. The rest I had to drill out myself.
