My custom coil relocation!!! PICS ADDED!
Old Oct 31, 2012 | 05:14 PM
  #81
babbage1109's Avatar
Do you have any pictures of them off the motor?
Old Nov 1, 2012 | 12:49 PM
  #82
PUNISHER TA's Avatar
Yes, I do. Ill try to get some up.
Old Nov 1, 2012 | 01:42 PM
  #83
Thank you
Old Nov 8, 2012 | 09:27 AM
  #84
Updates?
Old Nov 9, 2012 | 12:25 PM
  #85
UH-60pilot's Avatar
Thats a great idea.
Old Nov 9, 2012 | 01:11 PM
  #86
I didn't see any on my computer, Ill take some, someday, but not a huge priority for me at the moment.
Old Nov 29, 2012 | 03:44 PM
  #87
-TheBandit-'s Avatar
Punisher, have you had this engine running? If so for how long? Any issues with heat down there?
Old Nov 29, 2012 | 04:44 PM
  #88
I did, I put 1500miles on it, zero issues
Old Nov 29, 2012 | 11:09 PM
  #89
muttstang's Avatar
Damn those are killer lookin! Gotta feel great buildin those yourself...wouldn't mind re-locating my coils on my swap i have goin in my mustang.
Great work and love the motor set up as well...all very well done!
Old Dec 5, 2012 | 06:44 PM
  #90
LopeyZ's Avatar
That is a really clean install! I would worry about heat from the headers but I guess it works. Very nice
Old Dec 5, 2012 | 07:19 PM
  #91
Thanks
In real world testing on a 600+RWHP N/A engine, it was proven to not be an issue.
Old Dec 7, 2012 | 04:46 AM
  #92
Pony Exp.305's Avatar
the motor looks badass..
Old Mar 15, 2013 | 07:51 AM
  #93
nakedeye's Avatar
Thanks for this information.I was looking for this one that is about mattress.
"Cuz chances are there's a mattress on a statue a tooth missing and $50,000 worth of poker chips in his pocket"
Old Mar 15, 2013 | 08:32 AM
  #94
CrAzYGOAT's Avatar
WOW that is the best relocation i have seen... got me wondering how much room i have down there on the gto.
Old Mar 15, 2013 | 10:59 AM
  #95
Thanks man, this is definitely one of my favorite ideas. Cleans up the bay so well.
Old Nov 13, 2013 | 09:15 PM
  #96
ccso503's Avatar
Looks outstanding. Anthing new on the brackets? Have you started marketing them?
Old Dec 12, 2018 | 08:09 PM
  #97
Edwin Herrera's Avatar
Originally Posted by PUNISHER TA
Hey guys,
Work is a bit slow today, so I figured I would start this thread, ill have to add pictures tonight.
Over the past couple months I have been working on a new coil relocation kit, one that is different than any others I have seen.
Rather than move the coils under the cowl, I decided it would be cool to drop them down by the oil pan,
I made my own bracket, which took a ton of trial and error, but I finally got a set of brackets that fits awesome, and is very rigid.
It mounts on the two lower engine mount bolts as well as one oil pan bolt.
I made my own spark plug wires, with 90* boots on the spark plugs,
It is so sneaky, you can barely see any portion of the system when it is all installed.
I did have to extend my ignition coil wiring, but that was a non-issue because I was already re-wiring my entire harness.
Passenger Side
Drivers Side
Front
My loyal helper
Which brings me to the second part of this thread
(This part may get lost in here, but I am not so full of myself that I feel the need for two threads)
I pulled off all of the loom and untangled all of the wiring back to the PCM...
from there I look at what route would be the best for each wire,
i.e. rather than have the TPS/IAC wiring come over the top with the injector wiring, I ran it along the drivers side oil pan, along with the cam sensor, coolant temp, alternator, MAF, 1357 ignition coil wiring.
Back to work, I will expand and add pictures later.
did you ever make more of these? I wouldn’t mind buying a set off you
Old Dec 14, 2018 | 09:55 AM
  #98
enigmah's Avatar
Bruhh this guy hasnt been active since the thread where the chopped the whole front of his trans am off at the firewall. That thread was a major letdown. Says hes been logged in this year but meh, I wouldn't expect much of him
