Is a paint booth totally necessary?
Old Mar 26, 2004 | 02:23 PM
Scalpel's Avatar
Default Is a paint booth totally necessary?
If someone wanted to paint just a single item like a bumper cover, etc, could they still achieve excellent results if it's not done in a paint booth?
I'm sure there are precautions that could be taken to alleviate dust, etc.
Old Mar 26, 2004 | 02:38 PM
PlainwhiteZ28's Avatar
well its not neccessary, but from experience.
A well LIT and CLEAN environment is the key to a good paint job.
Old Mar 26, 2004 | 02:53 PM
Joe "Preachers Sheets" DIESO's Avatar
Humanitarian
You just need to make sure there is nothing floating in the air; your safe for the most part. Even one little strand of hair stands out like a sore thumb under paint & clear coat so make sure your in a clean room.
Old Mar 26, 2004 | 03:13 PM
JackZ28's Avatar
I've heard of guys painting show winning jobs in their yards, but if you don't have much experience, if any at all, you'll want to take all precautions. If you've never painted before, the use of a paintbooth is highly encouraged.
Old Mar 26, 2004 | 04:16 PM
Nine Ball's Avatar
LS1Tech Co-Founder
Levi, just make a small sectioned off "room" with some celophane or rolled plastic walls, and wet the ground down alot to help trap dust. Should be okay for painting a bumper cover.
Old Mar 26, 2004 | 05:22 PM
DARK AGE 53's Avatar
Let me add one more suggestion to that, cut out a small section of the plastic so you can place a cheap box fan on the floor. Set it on high and you should turn out nice, remember you can use micro sandpaper to remove and small defect then polish it out with 3M Finesse-it II Finishing Material ( this is what we used at the G.M plant I retired from ).
Al
Old Mar 26, 2004 | 05:23 PM
Steve1969LS1's Avatar
yea, what Tony said.. its more of a garbage in/garbage out.. you cant have a good paint job if dust, particles and even bugs are landing on your wet paint.. colorsanding can take out some of the stuff that will get on there.
Old Mar 26, 2004 | 06:11 PM
DaddySS's Avatar
I bought a cheap tent, covered the windows with filter paper, and attached my shop vac to the last window. Hung some plastic drop cloth inside with spring clamps and put a couple of flourescent drop lites inside. Made a great paint booth and wound up with a fun tent for the kids when I was done.
Old Mar 26, 2004 | 06:23 PM
Scalpel's Avatar
9Ball and Darkage, I had those plans in mind. I may just paint some small stuff, like headlight doors, etc first to see how it does. I have some buddy's car that are in need of some touch ups
