taking out fog lights
thanks in advance
thanks in advance
look underneath you will see three plastic push in screws, remove them and then you can get to the two bolts that holds the fog light assembly.
i had to replace mine couple of moths ago,because i drilled mine and i was getting water in the fog light, so i wouldn't bother with the stobe lights
hope this helps
