Relocating HVAC controls to glove box
Btw, to those asking why you need the screen in it, one word: carPC.
Think about it, you put a computer under the passenger seat, wire up a touchscreen LCD to the computer, load the computer with all of your mp3s, put some GPS navigation software on it, heck you can even get those rear-view cameras that are the size of a key lock, and then you can wire that to the computer too.. Oh, and to those with the Clifford Alarm systems, you can get software to then interface the alarm into the LCD screen, which is pretty cool in my opinion. Fun toys, gotta love the bells and whistles.
Possibilities are only as endless as the capabilities of the computer.
Use quick disconnects on all the wires. Lucky enough for us, almost all the connectors from the factory wiring are the perfect size for a quick disconnect to fit right on.
For the vacuum lines, disconnect them from the back of the A/C controls, and slide them through a hole you will find in between the glovebox and the A/C / Radio area. The hardest part of the whole thing is the black cable that is connected to the temperature selector. Snap that thing off then run it to the glove box area. At first it will feel like it doesnt have enough slack, but I believe you can easily re-route it so that you get a lot of slack.
If you have any questions, feel free to PM or email me.
To note progress on my install, visit my website www.thegev.com click on CarPuter. I haven't updated in a while, but will soon. I am about 75% done with the project and want to complete this one step I'm on (making the monitor work) and then I will post up all the information needed.
I'd crash.
EDIT:
dammit..... I just realized how old this thread is. Last edited by VIP1; Nov 30, 2004 at 12:06 AM.
Wicked 3800 V6: There is no way to relocate the ac controls without cuting and lengthening all of the electrical wires.
i wouldnt necessarily enjoy the air/heat controls in the glove box, and i wouldnt like losing that space to hold random ****...but i still like the idea and i think it looks a helluva lot better than stock
too bad i'd never spend my money on things like that
Then I extended all the wiring to the AC controls (16 wires, I believe) and used solder and heat shrink on all of the connections. Two of these wires are like 10 gauge wire, and I recommend using yellow butt splice barrels on these if you don't have a beefy enough soldering iron. All of the other wires were 14-16 gauge. Extending the wires into the glove box was the most time consuming part, but not that hard. The part that was hard as hell was moving the black cable attached to the temp selector over. I had to disconnect the cable from the controls, (3 screws, and watch out for the little BB in there!) then take the circular black part off the end of the cable, (three plastic tabs) to make the end small enough to be squeezed through the hole between the two spots. It is because of this cable, which comes from the center part of the dash behind the radio, that makes the glove box the only realistic place to move the controls to. Unless maybe you rig something up using a brake cable off a bicycle or something. There are also vacuum lines attached to the controls, and luckily they come from behind the glove box. They just need to be disconnected from the controls, and re-routed back into the area behind the glove box. Here's a pic I took avter all the wires had been lengthed, the cable, and vacuum lines moved as well. I was in the process of wrapping the extendes wiring with black electrical tape to give it a "factory" look.:
After I moved everything, I cut the back out of the glove box, and fabbed up a small bracket out of 3/4" MDF and hardboard. This is what the controls mount to, and this gets screwed to the back of the glove box after it's carpeted:
Then, I moved some relays to the upper dash cavity, and a black box (Don't know what it's for) to under the steering wheel, and I had cut out the ABS plastic divider the stock radio sat on earlier. This leaves me with a suprising amount of room:
The Motherboard that I plan on using is 7" square, and you can see from the pics there is about 9" x 9" x 10" of room in there. I believe that I shouldn't have too many problems fitting that motherboard, hard drive, and power supply in there, then covering it all with the 8" LCD and CD rom drive. Cooling shouldn't be an issue with the AC vents right above them. I'm sure it wouldn't be too hard to steal some air from the center vents. If you want, I'll post some pics up once I start installing things (1 Month).
First fiberglass project I've ever done, but the light makes it look more wavy than it really is.
My little bro's (NA$TY-TA) first TA... it was
For some reason the link my Bro used for my pics is dead so here it is linked from my site.......
Kyle
we used a little bit of Fiberglass
Kyle
