Checklist before I buy?
Old Sep 25, 2012 | 10:23 AM
dabest09's Avatar
Originally Posted by GoFast908Z
To strip the polishing oils before applying the sealant. If this step is skipped, the sealant will not bond properly and you will have weakened durability.
I've read on the forums that IPA wipedowns aren't good to use and don't remove every bit of oils on the surface, what's your take on this? Many guys on autogeek and other forums are recommending prepsol and other products instead.
Old Sep 30, 2012 | 06:14 PM
TwitchZ28's Avatar
Originally Posted by colinpd137
I actually have one more question for the masses, It seems my PC will NOT be coming with a "hook & loop" backing plate, which one would you recommend?
Well you have 5.5inch pads so you want a 5 inch back plate. You want the hook and loop(which is just velcro). i think mine is made by orange lake country or whatever...the same company that makes the pads you bought. I got mine from either autogeek or from amazon I can't remember.
I am using the standard counter weight with a 5 inch backplate without issue so don't worry about that.
