LED switch over completed !
Old Oct 11, 2012 | 01:01 AM
sjsingle1's Avatar
Default LED switch over completed !
I did the fronts first long ago......new sockets and housings......what a difference it made.....no more burnt sockets OR housings...........its a MUST HAVE in my book......I used the EL12 flashers for the front only conversion.......finally got the rears to finish up
used 3157 dual intensity 45 element SMDs in red for the turn/stops
a 194 15 SMD oversized for the end bulbs.....the oversize does fit
3157 dual intensity 45 SMD in cool white for the backup
FULLY electronic flasher for the turns
one of the new flashers ( i got 2...1 for flash and 1 one for hazards) crapped out in 5 mins so i stuck the EL12 back in for the flasher and it worked.....go figure
sjsingle1's Avatar
Old Oct 11, 2012 | 01:02 AM
sjsingle1's Avatar
sjsingle1's Avatar
be sure to check them.....one row was inop....it will be returned shortly
Old Oct 11, 2012 | 01:03 AM
sjsingle1's Avatar
back up is really bright and WHITE
Old Oct 11, 2012 | 01:04 AM
sjsingle1's Avatar
compared to stock dull yellow
Old Oct 11, 2012 | 01:05 AM
sjsingle1's Avatar
EL12 and electronic flasher
Old Oct 11, 2012 | 10:27 AM
DaRReLL's Avatar
Great write-up...
Old Oct 13, 2012 | 03:22 PM
sjsingle1's Avatar
with all the cussing and bitching and questions about LEDs.......i hope this gives some guidance to all the lost souls
Old Oct 13, 2012 | 08:16 PM
blackmaverick's Avatar
very cool
Old Oct 14, 2012 | 01:19 AM
transam5.7lt1's Avatar
Night pics installed?
Old Oct 14, 2012 | 07:06 AM
DaRReLL's Avatar
co/signs
Old Oct 14, 2012 | 02:27 PM
sjsingle1's Avatar
next time its gets dark i will see if my camera works in low light......it is noticeably much brighter......the over sized 194s on the end were really a good choice
i also have LEDs in the side makers....... much nicer
Old Oct 14, 2012 | 10:17 PM
junior98's Avatar
So you just put a fully electronic flasher in one of the slots (which one?) and all of them work as they should? The only led's in the back I have are the reverse lights and I'm not familiar with how to get the brake lights and such to work properly
Old Oct 14, 2012 | 11:46 PM
99'CajunFirehawk157's Avatar
IMHO, all these led vendors are selling us is junk and overpriced junk at that! They all start out fine, then one by one, one problem or another. I must have 3 diff vendors leds in a box where I buy them, install them, sooner or later one of both crap out. I just tonite put my yellow filament bulb 3156's back in my front turn signals. Seems the interior ones hold up, outside not so much. IMHO, YMMV.
Old Oct 15, 2012 | 04:50 AM
sjsingle1's Avatar
i have had my fronts in for over a yr..........not a single pro
Old Oct 15, 2012 | 05:08 AM
sjsingle1's Avatar
forgot i had the flash on............
sjsingle1's Avatar
Old Oct 15, 2012 | 05:09 AM
sjsingle1's Avatar
sjsingle1's Avatar
