Clear Corner Moisture Fix! Finally!
Ok heres the deal, I swaped my oranges out for clears and when I took the harness out of the oranges I noticed that only one of the harnesses socket had a rubber seal around the harness that goes in the turn lights. So when you put the light back in the socket it seals tight. Went to dealership to find a part number for it and like usual they had no idea and told me I had to buy the whole harness
. The lense without the seal was full of water already
. Took the rubber seal out of harness and headed to Menards. Picked up a o-ring about the same size and headed home to try it out. 2 weeks later, wala no more water in my clear corners
So, It worked for me! Very cheap too so if it doesn't work for you, your not out much, but worth a try.
Here's the o-ring info:
1-5/16 X 1-1/8 X 3/32
#64 O-RING
STK NO 35778B
Cost : A wopping .69 cents a piece!
Hope this helps ya all out
Tony
