Need help with Web Electronics sequential tail lights
Old Dec 30, 2012 | 06:09 PM
tnmotown's Avatar
Default Need help with Web Electronics sequential tail lights
Well I got the Web Electronics sequential tail light kit for Christmas, and just tried installing it today. Read the instructions over a few times before installing. Started on driver side first and everything went fine, tested it and it sequenced fine.
Now, I did the exact same thing on the passenger side (used green wire instead as the signal wire) and lights DID NOT sequence. The inner and middle lights flash at the same time, and the outside light doesn't flash at all.
I've tested all connections and made sure they were secure and going to the right color wire. I switched the light bulbs from the other working side, and didn't do anything. I don't believe it should be the flasher relay as it is working?
Any ideas or input guys? I can take pics if needed. I'm going to email webelectonics and hopefully get a response.
