Steering wheel adapter
Old Jan 5, 2013 | 04:04 PM
spilner's Avatar
Default Steering wheel adapter
What are you guys running? I want to upgrade my steering wheel in my 95 TA. Anything out there reasonable?
Thanks
Old Apr 26, 2013 | 11:59 PM
1961ba427's Avatar
You've probably already figured it out by now, but if you are going with a Grant (or Pilot) steering wheel just get the adapter that you'd use to put it on a 3rd gen. Grant #3196 if I remember correctly. Most people need to trim the collar down slightly so the adapter doesn't rub the column. I just spaced mine with 3 thin washers for the time being. I'm running a Pilot leather wrapped wheel with a Pontiac Horn button from Grant. It looks good and is alot lighter too. My airbag light is now on, but I have read that a 1.3 ohm resistor installed in the airbag connector at the base of the column will turn the light off and let the passenger airbag still function. Finally found the resistor online from Radio Shack, but haven't gotten around to installing it yet.
