wet sanding question
Old Feb 6, 2013 | 07:06 PM
JerseyLS1TA's Avatar
Default wet sanding question
I would like to wetsand the tailights and panel in between. I was wondering if its necessary to use a buffer or can it be done by hand to get the lite scratches out?
Old Feb 6, 2013 | 07:46 PM
redline61's Avatar
By hand will work well but just be sure to use very fine sandpaper. Also to shine up taillights I was shocked with how well those buffing ***** you put on the end of a drill work with some polish.
Old Feb 6, 2013 | 10:48 PM
Daniel Richards's Avatar
ANY wet sanding of taillights is going to leave some amount of haze, you'll need to go back after and polish them, or if you prefer a more extreme fix clear coat them after polishing.
