TSP LS Coil Covers?
Old Feb 18, 2013 | 05:46 PM
z-maro's Avatar
Default TSP LS Coil Covers?
Has anyone here used these LS1 Fabricated Aluminum Coil Covers? I have tried to search but came up with noting. I talked to a guy from TSP on the phone and he said that they work on 4th gen Camaro's, but didn't even know that Firebirds came with a V8
If anyone has any info on them that would be great.
One concern is that you have to replace the oil filler tube, is this possible to do without removing the valve covers?
Thanks
And yes, I know this isn't the same TSP we are used to around here.
Old Mar 4, 2013 | 05:29 PM
zachary3's Avatar
$109 on amazon
there coil covers there not valve cover
they mount over coil to cover coils
pretty simple concept no you dont need to remove valve cover oil filler
even then if you had to its a very simple process
help that helps
Zach
Thanks
