Clear Corner LED Setup
Old Mar 18, 2013 | 10:06 AM
BAD2theBONE's Avatar
Default Clear Corner LED Setup
So I researched on here and I'm guessing my word choices weren't to "key" because I had only found one thread dating back to '03... it had some useful information as far as bulb #s and what flashers I'll need to replace with to allow the LEDs to blink... but overall I've found this website to be more than useful www.superbrightleds.com
My questions are as follows: My sockets where the LED bulbs will go are FRIED, what part number is a new lighting socket for them and do they have to be spliced to connect the new sockets?
What would you suggest to go with for a clear corner? An 18, 26 or 45 SMD LED bulb??
I'm thinking about going with these, but they say "CAN BUS bulbs should not be used in non CAN BUS applications???
Which ones then??
http://www.superbrightleds.com/morei...ed-tower/1263/
http://www.superbrightleds.com/morei...led-tower/633/
Old Mar 22, 2013 | 10:20 AM
Anyone ever install LEDs in their corners??
Old Mar 22, 2013 | 11:03 AM
BadBirdie's Avatar
if you havent already go to google to search. type in ls1tech, then what you are searching for. such as "ls1tech led clear corners". works alot better than the search feature here.
Old Mar 22, 2013 | 04:43 PM
sjsingle1's Avatar
i used 5 smd leds in mine.......but i dont have clear corners......there is a size limitation so you cant really get much bigger than the 5 smd in there
Old Mar 22, 2013 | 05:45 PM
SparkyJJO's Avatar
Here's a writeup I did on another site on how to rebuild your sockets without rewiring, including the part number of the socket you need from Autozone (Dorman makes it IIRC):
http://www.fullthrottlev6.com/forums...-a-single-wire
Old Mar 25, 2013 | 12:50 AM
Khaalathas's Avatar
thx for the link sparky needed this info myself as well
Old Mar 25, 2013 | 06:39 AM
Atrus_SS's Avatar
I just ordered and put some in my SS.
Not knocking superbright at all as I have been happy with everything I have purchased from them, but they are pricey.
IIRC, it was going to run me like $18 ea for the 1157's and $6 ea for the 194's from superbright. I went on fleabay and got VERY similar bulbs for $16 shipped. These fit perfectly, the 194 can't be any larger than this. Not sure if there'd be extra room to fit a bigger 1157, but these worked great.
5 SMD 194 Replacement
13 SMD 3157 Replacement
Only problem with the 194 replacement is there's the LED on the top, creating a hot spot. I painted over it. Now there's a slight cool spot, but I'd prefer that anyway.
