what do you recommend?
Old May 4, 2004 | 04:19 PM
OWENMUSTANG's Avatar
i have used 3m swirl remover (for dark colors) with liquid glass (the 1 in a can
with the red vette) looks good. not great. you may want to try a rubbing compound
to start with(all the different products won't help your funds, but it will yield better
results..and quicker too!)
Old May 4, 2004 | 10:04 PM
tuffluck's Avatar
Originally Posted by SuperBuick
If you want to do it by hand (the right way) tuffluck, get some Meguiars Dual-Action Cleaner/Polish and then talk to Scottwax over at autopia. He does most of his swirl removing by hand using thie product. It is very time and physically consuming as I understand it but it can be done.
Like 6']['9 says "its not what you use its how you use it"
-Tom
where can you buy that meguiars stuff locally? i only see the other "normal" meguiars products.
Old May 4, 2004 | 10:15 PM
6']['9's Avatar
at a body shop theres one here in sa that sells it.
Old May 4, 2004 | 10:56 PM
Brandon Boomhauer's Avatar
check oriellys, they carry alot of the meguiars professional stuff.
SuperBuick, why does Scottswax do it that way? Just preference? or what?
Old May 4, 2004 | 11:20 PM
ZaneO's Avatar
Another product that is supposed to work pretty well by hand is Vanilla Moose made by ClearKote. DACP and VM combo would probably work pretty well.
www.clearkote.com
Old May 4, 2004 | 11:39 PM
Ah, I've read alot about it on autopia but never saw who made it..
Old May 4, 2004 | 11:47 PM
6']['9's Avatar
scott does it like that cause hes a badass, he just recently got a pc. but his work is pretty good.
Old May 5, 2004 | 12:53 AM
Ah, I thought he had one but didnt like using it for some reason...
Old May 5, 2004 | 02:01 AM
tuffluck's Avatar
there sure are a lot of you guys in texas. hopefully one of ya'll can swing by austin some time with that PC and help me out!
Old May 5, 2004 | 08:07 AM
SuperBuick's Avatar
Yeah - Scott is just badass - he does it that way I guess just because he can? Nonetheless he does some awesome work.
Zane - I completely forgot about the ClearKote stuff - good reccomendation. I believe Scott uses that as well.
Bottom Line Tuffluck - it is alot more work and technique, but it can be done (at least partially)
-Tom
