Interest in new cheaper TARGA alternative...
It would be a kit that would allow you to cut out the stock, heavy, center t-bar section.
We would have two replacement metal panels (with holes to tack weld in or just use screws as the holes would be recessed so the screws would be flush and look finished) that would go where you cut the t-bar out (so that it would look like a finished channeled targa roof).
Then one cut on each side of your factory weather stripping and it would reapply as a targa weatherstripping.
Next you would remove your t-top center bracket from the bar you removed and you would screw it into a new center bracket that we supply.
This new bracket would only be as wide as the center bracket itself. It would latch into the metal panels we're supplying.
SO, long story short, when finished, your car would look like a normal car with your t-tops on, then when you want to cruise, you take your t-tops off like normal, and then also unlatch this center piece, store it in the back, and your car would look like any other targa car with the top off.
This is the only viable means I have found to being able to have a "clear" roof when installed and full targa when removed.
Thoughts? No idea on pricing yet, need a car to try it on, just seeing if it sounds interesting. Would drop about 20lbs off the car. Obviously you'd need subframe connectors though.
http://6litereaterdesigns.com/store/...roducts_id=507
https://www.facebook.com/media/set/?...1202051&type=3
