Custom Door Panel Inserts
Old Jan 24, 2014 | 01:53 PM
xBrandonx's Avatar
Default Custom Door Panel Inserts
Need help doing my inserts! I have the vinyl wrapped and ready to install. I destroyed the little black clips to get the cardboard off. How do you go about reinstalling it? I used screws and cardboard washers and screwed them into where the white clips were since you won't see it but you can't for the black ones.
I tried using Epoxy to hold down metal clips on the door then I would slide the cardboard thing over them and bend it over to hold the cardboard in place. Only like 3 clips worked, the rest of them broke.
Can I just try to slide whats left of the black tabs on the cardboard and use a puddle of Epoxy to hold it with a clamp?
(not my pic, this is on a Camaro, the rest are mine though)
Old Jan 24, 2014 | 02:10 PM
J LT1 TA's Avatar
This is what i did and it worked pretty good. Get a soldering iron and use the leftover plastic from a modeling kit and melt it. Hold down the insert an melt the plastic on to the old tabs. Make sure your outside.
Old Jan 24, 2014 | 03:33 PM
xBrandonx's Avatar
Old Jul 13, 2014 | 09:28 PM
Ghostintheshell's Avatar
Is this seriously the option? Soldering iron the remnants of plastic?
Old Jul 14, 2014 | 11:39 AM
xBrandonx's Avatar
I used melted plastic on my ebrake boot. If I would redo my doors I would use melted plastic again..way better than hot glue
Old Jul 14, 2014 | 10:06 PM
How did you secure your fabric? Did you glue it to the cardboard panel?
Old Jul 15, 2014 | 11:55 AM
xBrandonx's Avatar
Staple Gun along the edge where you don't see
