Install Cage?
Old May 11, 2004 | 02:45 PM
RedDevil's Avatar
Default Install Cage?
We're working on a 6 point bolt in cage... the rear 2 arms bolt in and mount not on the rear deck, but instead against where the back of hte back seat rests and it would go right over the rear seat and close to the side.. i wish i could describe it better.. anyways, the place where the 4 bolts will go in to hold each of these arms, is against that panel where the back of hte back seat goes.. which, if i recall, is DIRECTLY next to the gas tank? what is the best way to drill and bolt these down? Lift the car? drop the gas tank? can you do that with gas in it?
