Engine Bay Cleanup!
Old May 27, 2014 | 09:38 PM
Bill2002's Avatar
Default Engine Bay Cleanup!
Well, I went ahead and did the wire hide mod. It did turn out pretty good. The wires were a little tight so I am using the bottom of the clips and tie wraps to hold up the wires. I also ran the wire that goes down and plugs in below the frame (don't know what it is) behind the inner fender. It seems to be holding in place. I will make sure it isn't hitting the inside of the tire. I don't know if I will protect the wires that can be seen, since the car doesn't see rain. I know one day I might get stuck in the rain, but for now I think I am good. I still have to get some kind of grommet to put around the hole I cut. I thought I had some alligator grommet left, but nope. I still have to do the drivers side. But I have to idea what it is on that side, I haven't looked into that much.
Old May 27, 2014 | 10:26 PM
TitanZ06's Avatar
looks good!
Old May 27, 2014 | 11:46 PM
Majestic9C1's Avatar
now toss that traction control/cruise module behind the PCM.
Old May 28, 2014 | 02:03 PM
CamaroSS27's Avatar
Old May 28, 2014 | 08:43 PM
Bill2002's Avatar
I did the other side tonight. The traction control relocation, now that makes me nervous. I would love to relocate the coil packs and smooth the valve covers, but that might be a little to extreme. Plus, where the hell would I put them!!
Old Jun 1, 2014 | 08:02 AM
Bill2002's Avatar
The TC has been moved. What a pain in the butt. Trying to get the TC to stay while I put the PCM back in. But it is finished. What can I fill the holes with that won't look to bad, and without painting. I thought about black silicone.
Old Jun 1, 2014 | 09:10 AM
Leonidas's Avatar
Yes, I just did this yesterday and moving the Traction Control behind the PCM was a pain in my ***! Took me about 3 failed attempts and 2 hours to figure out!
