window doesnt roll all the way up
Old Jul 13, 2014 | 07:40 PM
Huffdaddy13's Avatar
Default window doesnt roll all the way up
I have a 95 fire bird and the driver side window doesn't roll up all the way just about 1/2 an inch just enough to let the rain In on me and it also seems to need pushed in a little I think I'm missing some piece in the door. Not too sure though. Any help is appreciated!!
Old Jul 13, 2014 | 08:04 PM
JustAFooL's Avatar
Typical problem with these cars. Motor is getting weak. They also make a hotwire kit that runs straight off the battery and gives it more juice.
Old Jul 13, 2014 | 08:22 PM
I'm almost positive the motor and wiring is fine it doesn't roll up slow or get stuck or anything. I'm thinking there a a rubber/felt piece or something that pushes it in that came out.
Old Jul 13, 2014 | 08:58 PM
cptobviouss's Avatar
while it could be the motor. in my case it wasnt. After removing the drivers door panel i came to find that after letting the window automatically, it lets it self bottom out. The motor torqued the bolts in such a way it dug itself farther down in side the door. Essentially that it was mounted about 1/4 lower in my case. After screwing the motor assembly back into its original position, jb weld, and aluminum, to keep it from torquing its self down its been good for a year.
Old Jul 13, 2014 | 09:18 PM
autogeek23's Avatar
Do a search. Mine does the same. Common...
Old Jul 13, 2014 | 11:56 PM
Ok thanks I'll have to give it a go ASAP Damn things been bugging me for months
