SCG Pro - Machine Cut™ Polish
Remove swirls, scratches, and 1500 to 2000 grit sanding marks with SCG Pro Machine Cut Polish. The custom hybrid-abrasive blend utilizes two distinct types of cutting agents to provide powerful swirl and scratch removal, but still finishes down so clean, often eliminating the need for a second step! Absolutely no silicone means, Machine Cut™ Polish is body shop safe and effective with dual-action, orbital, and rotary polishers with foam and microfiber pads.
Discover what perfection can look like with the amazing paint correcting power of SCG Professional Machine Cut Polish!
Directions:
NOTE: Always begin with a clean and dry surface.
- Prime pad by applying approximately 10-12 pea sized drops of Machine Cut™ Polish evenly over the face of a moderate to aggressive polishing pad.
- With machine at low speed, spread product over section to be polished.
- Increase machine speed and work the polish until it appears thin and oily
- For additional panels use only 2-4 additional drops of polish.
To prevent product buildup, clean or replace pad as needed.
