Door Switch Lights
Old Sep 9, 2014 | 07:14 PM
38DD2436's Avatar
Default Door Switch Lights
I was replacing my front speakers and with the door panels off I tried to remove the bulbs for the door switches. The bulbs don't want to come out very easily. I stopped tyring before I broke some thing. Can these be replaced? If so, how do they come out.
Old Sep 9, 2014 | 08:22 PM
CoreyD's Avatar
Are you talking about the courtesy lights? The ones that are right by the handle?
Old Sep 9, 2014 | 08:38 PM
stealth355tpi's Avatar
Are they burned out? The size for them is a 74. Usually with those tiny bulbs it's easier to break them and pull out the rest with pliers. Just make sure the lights are turned off so you don't pop a fuse.
Old Sep 9, 2014 | 09:39 PM
YURVIEW's Avatar
I had to like, stealth. Those little suckers don't want to let go!!!
Old Sep 10, 2014 | 06:35 PM
38DD2436's Avatar
The bulb that is underneath the window switches by the door handle
Old Sep 10, 2014 | 06:38 PM
38DD2436's Avatar
Yep, Burned out.
Old Sep 10, 2014 | 06:48 PM
Majestic9C1's Avatar
I crushed them with pliers and then pulled them out by the filaments...
replaced them with white 74 bulbs from super bright leds
