HID Conversion on a 98-02 Camaro
The bulb size, I actually didnt know that HID's could come in the stock 9006 bulbs, but my car came with aftermarket headlights with halo's in them using H1 Bulbs so Im guessing I would need to order the H1 kit correct?
thanks.
Yeah I was concerned about that too but my aftermarket lenses have H1's in them and it appears they already have the projector installed .. I will take a photo and post alittle later.
Oh and one other thing. I know that HID's aren't recommended for bright lights because the ballast doesn't like frequently being activated and deactivated, however; on the low beams... 98 - 02 Camaros come with automatic lighting meaning the headlights automatically turn on when it gets dark enough... And they are also triggered when sitting under an overpass for a minute or two... How will this effect the life span of these lights?
Regarding the wattage, 35W is safe option. Going 50 or 55W will add more heat and unless you know the projector can handle this, you might have issues down the road. The extra heat can damage the internal reflective coating of the projector ultimately reducing light output.
If going DDM, get the H1 kit and these should plug into your existing 9006 low beam connectors.
If going Morimoto, I would get the H1 kit and 9006 relay harness.
If you are looking to order a Morimoto kit, feel free to PM and we can get you setup with exactly what you need.
At least those sonar projectors put out some useable light unlike the eagle-eye and other similar brands which have bad beam patterns and are dim overall.
You can try a H1 HID kit in those and if they aren't enough, you can buy the BLS headlights without an HID kit and use the H1 HID Kit you bought. Its a "graduated" approach to spending only what you want/need.
Not all HID kits are made the same. So be aware of really cheap ones. Their output will be lower. Avoid DC ballasts and stick with AC ballasts. The AC/DC refers to the output of the ballast (to the bulb) and not the input (from the car), since the input from the car is always 12-14V DC.
You should see a beam with a bright spot near the top center and gradually decreasing brightness down and to the sides. If you see any dark spots or dark rings or dark streaks or no bright spot then those projectors are faulty or the bulb isn't seated right in the projector.
This also isn't the proper way to do HID, but a "band-aid" that sometimes works sufficiently.
Funny thing about the Morimoto Mini H1 HID Projectors the BLS uses is that although they are designed around H1, they are designed around an H1 HID Kit bulb and not a Halogen H1 bulb. So they are a real aftermarket H1 HID projector. Pretty much every aftermarket headlight housing on ebay that uses a H1 bulb regardless if they come with an HID kit are still using low quality Halogen projectors that don't even output well with a good Halogen bulb and don't get much better with HID (since differing optics needed for HID vs Halogen and they are not well designed for Halogen to start with).
That said, good projectors from someone like BLS are certainly superior.
