power to manual options
Old Dec 17, 2015 | 03:47 PM
Blackbird-WS6's Avatar
Default power to manual options
Has anyone swapped there full power car (power windows and locks) to manual windows and locks?
Do they even sell parts to do the swap?
Any info would be great. Thanks.
Old Dec 18, 2015 | 10:19 AM
sweetbmxrider's Avatar
Ebay should probably turn up some stuff. To do it completely, you need manual window regulators with cranks, switch delete blanks for the trim, and manual mirrors. The regulator rivets in, there is a hole marked "M" on the door and the rest lines up from there. The door panel needs a small hole cut into the carpeted area, its obvious when the regulator is in. The locks need nothing, they are manual if you don't use your switch. Mirrors are cable adjustment on the base and have their own special trim piece as well.
