LS1 Piston Display First Try
Old Apr 17, 2016 | 03:08 AM
fstr n u's Avatar
Default LS1 Piston Display First Try
Since grenading my original LS1 engine, my 8 pistons have been kicking around collecting dust. After many Crown Royal and Coke Zero's i decided to build a display for one of the decent pistons remaining.
I welcome thoughts as this is my first go around.
Old Apr 17, 2016 | 03:11 AM
fstr n u's Avatar
I took an old plaque, ripped the brass face off, cleaned it and sprayed it black.
I then took a piece of very thin wood panelling and cut it around 1" wide by 5" long and used that as the "plate' between the piston base
I cut a 2"x2" piece of wood as pegs (times 2) and used those as the legs to suspend the base of the piston off the black plaque. Holes were drilled where the pistons bolts needed to go.
Old Apr 17, 2016 | 09:15 AM
Double-aught_Z/28's Avatar
They make nice lamps too. I put this one together.
Old Apr 23, 2016 | 08:20 AM
Flying Dutchman's Avatar
cool idea and good way to clean up all those old parts lying around the shop. I have seen some pretty neat coffee tables made out of parts also!
