Corbeau FX1 Seats Installed
Everything went together OK except the placement of the seats. Where the holes were drilled on the brackets pushed both seats into the center console. The driver side was so far inboard that I could not adjust the seat back and forth due to it being against the center console. I ended up drilling new holes in the bracket 3/4" over which worked great. I need to drill new holes for the passenger seat over the winter, but it does fit as is.
The seats do seem to sit a bit higher than the stock seats (my stock seats were leather non power assist with electric lumbar) which is what I wanted as I'm a small dude. I also added a few washers between the bracket and sliders for a tiny bit more height. Even so, there is still a few inches from the top of the seat to the headliner. If you are a tall person, directly mounting the seat to the bracket with no slider might be the way to go.
Weight of the seats came in at 18ish pounds each. With the double locking slider, the seat came to 24lbs. I didn't check the weight on the brackets. My stock seats weighed 40lbs on the dot, they are surprisingly heavy.
With all that said, I'm extremely happy with them. They do a much better job of holding you in. Getting in is a little bit more difficult due to the high sides of the seat. I need to look at a better solution for seat belts. A guide is needed for the neck area and also the lap belt clicker near the console is hard to click into place. I will most likely look for a non rigid lap belt clicker.
something like this
https://corbeau.com/other/accessories/harness-pads.html
I got some driving time in on mine today and I ended up taking the washers between the bracket and sliders out, the seat was way too high. Even now, its still pretty high up. I have to relearn the clutch and gas engagement points, your feet are at a completely different angle now, I felt like it was my first time driving the car haha. I will say the seats are really comfortable, I was expecting rock hard and they have padding in all the right places.
