LED for HIGH BEAM..........plug-n-play.....does it exist?
this was all part of a headlight assembly rebuild and mod for the 9011/12 bulbs....it was not very easy...the rebuild was....very ....VERY time consuming.....parts hard to find....lots of rust to deal with and missing parts.....if anybody needs to know how to do it .....i am the expert now
You are the first to post pics of what needed to be modified for right angle bulbs. Thanks for the pics. Can the bulb be twisted out of of the housings with the housing is still mounted or do you have to remove the housing to remove the bulb?
I have projectors so showing what I trimmed on my buckets wouldn't help here (my rear aluminum frame/buckets are trimmed even more and I'm not using the steel "front" buckets anymore).
being first.....its what i do best
now if just one person shows interest.....i will do a rebuild thread.....it really is a PITA to do it ....but where else ya gunna find all those parts GM does not sell ?
Just wondering if it's set up for proper aiming/reflection or if it would be one of those "all over" beams.
Otherwise, the LMC housings appear to be the best output available for stock-like appearance. However, they are not intended for HID. They are Halogen Reflector Housings.
Technically the Hella 60mm projectors are Halogen as well, but they have shown to perform acceptably with HID.
Here is one such listing for the brackets on ebay:
https://www.ebay.com/itm/Hella-60mm-...X7dhtIqnb_uJNg
Here is the Hella 60mm low beam on Amazon:
Here is the Hella 60mm high beam on Amazon:
If you dont like Amazon, you can find the projectors on ebay and RallyLights (Susquehanna Motorsports).
If you look in the Lighting FAQ, you can see what others have done in the past.
https://ls1tech.com/forums/appearanc...hting-faq.html
I also just found these on The Retrofit Source which look interesting:
https://www.theretrofitsource.com/un...headlight.html
They are relatively cheap at $120/pair (without HID bulbs or ballasts).
I asked TRS for more info on them. They don't have output pics yet and they don't know what projector is in there (someone else makes these for them), but they did tell me the dimensions:
Length: 5.5"
Height: 3.5"
Depth: 5.5"
Might be able to make them fit.
Either option doesn't look too bad. Relatively inexpensive for either if I start with just low beams (120 for the housing/projectors or 150 for the brackets and Hellas, plus another 120 for morimoto d2s 2stroke 2.0 LED bulbs).
I wonder if anyone has tried these: https://www.theretrofitsource.com/jw-speaker-8800.html
Also, what does everyone do for the wiring? Is there a pigtail available or does everyone chop off the factory connector? I like to avoid doing that if I can.
In some scenarios, LED may be an upgrade for a Halogen Housing, but not an HID Housing.
https://ls1tech.com/forums/appearanc...enty-pics.html
