Tail lights warped/dented camaro
Old Feb 21, 2019 | 09:17 PM
edzsilverss's Avatar
Default Tail lights warped/dented camaro
Is there any way to reshape warped/dented tail lights on a camaro...im sure its from long ago when i had blackouts on them...heat from those and the bulbs dent them in...should i just buy a good used set or can the be reshaped?
Old Feb 25, 2019 | 11:54 AM
hokeplaya05's Avatar
pretty sure they all have that type of "dent" in them, at least mine do. i assumed it was from the molding process at the factory or something
Old Feb 25, 2019 | 04:23 PM
Fabian's Avatar
Neither of my 4th gen's are warped. I just checked my 02s to make sure. Hell, I'd never even seen that before
Old Feb 25, 2019 | 05:31 PM
quiet_storm98's Avatar
Happened to a set i had on my old car due to the blackout covers i had on them. Luckily the set on my current car don't have that issue. As far as a fix i guess you could try to heat up that area of the light and then push the dent out but i dont know how well that will work
Old Feb 25, 2019 | 06:35 PM
Yeah definitely not a factory option lol...its from the blackouts and heat from the bulbs...i will try to heat them up in the oven and see if i can press the dent out...might just go back old school and buy some more blackouts...tail panel is gloss black now...
Old Feb 25, 2019 | 08:50 PM
Spamfritter's Avatar
I've got a 2001 and a 2000 Camaro SS. One of them has the same deformity in the tail light.
Old Feb 26, 2019 | 11:30 AM
hmmm wonder if my car had covers on it at some point then, both mine are warped in the same spot on both sides
Old Feb 26, 2019 | 02:11 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
As mentioned above, this isn't a "factory defect", it's from heat build-up due to the usage of blackout covers at some point (or some other type of exposure to heat which exceeds what would be seen under normal usage). The only ones I've ever seen in person with this exact type of "dent" are examples which were known to have had blackouts prior. FWIW, none of my three 4th gen Camaros have ever had this problem (and they've never had blackouts).
Old Feb 26, 2019 | 03:33 PM
Mine just has it on the one side but I can't say for sure if it ever had blackout covers on it.
Old Feb 28, 2019 | 07:05 PM
LetsRide's Avatar
Mine never had covers nor do they have a deformity.
Old Mar 1, 2019 | 01:41 PM
transam5.7lt1's Avatar
Try a heat gun and push from the inside to see if it works.
Old Mar 4, 2019 | 03:48 PM
BGMZ28's Avatar
My SS had this issue. It was from the previous owner having used blackout covers on the car. I ended up just buying some non-deformed ones off craigslist for $40 and I later sold the deformed ones for the same price to someone who didn't mind the little indentations.
