How to remove e brake handle?
Old Aug 24, 2019 | 04:31 PM
bad_408_vert's Avatar
Default How to remove e brake handle?
I知 trying to remove center console and I知 stuck on e brake handle. What痴 best way to do it?
Old Aug 24, 2019 | 06:02 PM
Majestic9C1's Avatar
E Brake all the way up (obviously)... If its an auto console put the selector in 1st gear...
to get it off you will need to pull the rear up and rotate the back end of the console to the passenger side and then slide it up and off.. to get it back on you do the same thing in reverse
Old Aug 24, 2019 | 07:04 PM
Will the console just slide over the e brake handle as is?
i won稚 have to disable the grip handle on it?
Old Aug 24, 2019 | 08:34 PM
yeah it will go over it..just barely .. you dont need to remove the padded portion... but you can if you dont feel comfortable doing it
Old Aug 24, 2019 | 09:14 PM
Thank you
