Quick release steering hub help!!!
Old Aug 2, 2020 | 02:26 PM
Turbo306Fox's Avatar
Default Quick release steering hub help!!!
Im looking for a quick release steering wheel hub for a stock 4th gen steering column. Does anyone make a direct fit hub? I'm trying to avoid adapters and welding ect. Any help pictures links ect is a help! Thanks guys
Old Aug 2, 2020 | 11:38 PM
Big bird55's Avatar
i use an nrg hub and nrg quick release and nrg wheel.
hub - NRG SRK-170H
https://www.amazon.com/gp/product/B00HLPMEK6/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B00HLPMEK6/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
and I used this release.
https://www.amazon.com/gp/product/B00LBNJGGO/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B00LBNJGGO/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1
To get the air bag light off I used a 2.2k ohm to bypass it.
Plus my horn still worked.
also used the nrg hub on my 1st gen s10 and was told i could have used this on the s10 which makes me think it should also possibly work on these cars. its sfi rated approved
https://www.jegs.com/i/Grant/470/302...FdU9gQodibwFeA
Old Aug 3, 2020 | 01:21 PM
hub - NRG SRK-170H
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
and I used this release. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
So so you had to put an adapter hub plus the quick release on? Does that make the steering wheel sit further back closer to the driver?
Old Aug 3, 2020 | 06:34 PM
hokeplaya05's Avatar
i have a momo hub on my car which allows the use of any 6 bolt wheel or quick release (i just have a wheel, no quick release). install the hub in place of your stock wheel then bolt the quick release to that then the wheel. yes it will push the wheel closer to you
Old Aug 4, 2020 | 12:15 AM
Big bird55's Avatar
i think it pushed the wheel 3/4 to 1.5 inches out at most. i actaully prefered it. also the smaller wheel gave me more leg room ill get pics tomorrow.
Old Aug 13, 2020 | 11:30 PM
Big bird55's Avatar
pics
