Custom lt1 gauge cluster bezel
Old Aug 8, 2020 | 11:13 AM
slckstr96's Avatar
Default Custom lt1 gauge cluster bezel
This may not even be possible but has anyone custome made/modified an lt1 gauge cluster bezel to fit the Holley 12.3 dash? Any guys do custom forming? Can anyone fill the whole gauge opening to fit a panel? I'm running the motion leight weight steering column so there is more room at the bottom of the bezel also.
Old Aug 12, 2020 | 06:16 PM
blackbyrd's Avatar
It's gonna be a tight fit, been looking at the same idea. The bezel is gonna obscure the corners a bit and the space above the column is barely talk enough. You will have to trim the hump on the bezel that goes over the column to give you clearance.
Old Jun 20, 2022 | 03:23 PM
No Juice's Avatar
There was someone doing this in an LS1 cluster, got to think it would be the same process. Can't seem to find the thread though
