DupliColor Scratch Fix 2in1
Old Jul 18, 2004 | 11:06 PM
BLOODTA's Avatar
Default DupliColor Scratch Fix 2in1
I need to find some DupliColor Scratch Fix 2in1 for my car. A 2000 TA. I think I found the paint code. Does this make sense? U 408G My car is Maple Red Metallic.
Old Jul 19, 2004 | 03:50 AM
botsigLS1's Avatar
Duplicolor has a pretty easy match system. If you look at the driver side door on the service part ID label you see your vin #.
There is a grid of 3 char RPO codes. The last incomplete roll, 2nd group to the left. is a 2-# followed by 1-letter. The # should be your GM manufacture color code. This can be cross-referenced w/ the duplicolor match guide.
That should do the trick.
