Fog Light switch
Old Dec 24, 2020 | 03:07 PM
Blksilvr's Avatar
Default Fog Light switch
Something odd happened today when I turn on the fog lights.... When I turn then fog lights on... the head light high beam indicator turns on ....the fog lights do not come on. No fuse is blown .... has anyone ran into this issue before.
Thank
Rik
Old Jan 31, 2021 | 02:05 PM
Nbgorman427's Avatar
Thank
Rik
I have the same issue, you have led headlights by chance? The two circuits are tied together so that when you turn in your high beams, the fogs turn off
If you DO have LED high beams, they will probably stay on even if you toggle them if you have your fog lights on. If that's the case, turn your fogs off, then toggle your high beams again and they'll turn off
