ZL1 shift knob help
Old Jan 5, 2022 | 07:30 PM
95civic2005's Avatar
Default ZL1 shift **** help
Can anyone tell me which shift boot goes with this shift ****? I’m looking for my 2000 SS. I really want a factory H hurst **** but refuse to pay the ridiculous amount they are selling for. I feel this is as close as I can get to one and these ***** can be had cheaper than this particular ad.
https://www.ebay.com/itm/255038893753?hash=item3b6180aeb9:g:GnoAAOSwhjZg36i I
Thanks and I appreciate the help!
Old Jan 5, 2022 | 11:59 PM
VIP1's Avatar
Copy & Paste Moderator
Searching on ebay, I found a cheaper listing
https://www.ebay.com/itm/324738933710
If you want to install that on a 1998-2002 Camaro, you'll have to get custom/creative with the shift boot. Basically, buy the shift boot for the 2010 Camaro and modify it to fit the 1998-2002 Camaro. I saw some combo **** and boot listings on ebay, but the base of the **** was a different so I'm guessing that boot won't fit right on the bottom of that **** either. Might have to customize. Maybe you can make fit the 1998-2002 boot over the bottom clips of that ****.
There are also some similar aftermarket ***** without the SS / ZL1 / Hurst branding that would fit as well and not have those clips on the bottom.
Old Jan 6, 2022 | 06:58 PM
Do you have any links to the ones that are aftermarket? I’ve tried searching with not much luck.
I figured I would have to modify the the boot to fit, which I’m fine with, but I can’t find a boot that will fit the bottom of that ****.
Old Jan 6, 2022 | 09:29 PM
VIP1's Avatar
Search ebay for 1998 - 2002 Carmaro leather shift **** and you'll find them.
Old Jan 6, 2022 | 09:54 PM
VIP1's Avatar
Also, from what I'm seeing, to use the **** from a newer Carmaro, you need a "conversion stick"
https://www.ebay.com/itm/294309444148
https://www.hawksmotorsports.com/97-...ort-stick-kit/
https://www.hawksmotorsports.com/97-...onversion-kit/
This **** is a bit different than the one in the above posts. I can't tell if that other one is threaded either to actually thread onto the shaft on a 1998-2002 Camaro.
Old Jan 7, 2022 | 05:38 PM
Yeah I’ve seen those conversion kits. I’m not a huge fan of that **** though for some reason.
I appreciate your help with this!
