Seat belt question...
Old Nov 23, 2022 | 11:51 AM
wannafbody's Avatar
Default Seat belt question...
When reinstalling my passenger seat, I realized that it looks like the seat belt was twisted when it was assembled at the plant. Is anyone else's car this way? I don't think this is normal and wonder if the bolt can be removed at the floor and the anchor flipped and reinstalled?
Old Nov 23, 2022 | 01:08 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
I haven't had this problem with any of my F-bodies, but my wife's 2012 Malibu came this way (twisted passenger side seat belt). I've never bothered to fix it, but it should be repairable as my 2010 model (which is the same car) didn't come that way. It must've just been a mistake/assembly line flaw.
Old Nov 23, 2022 | 06:28 PM
NC01TA's Avatar
I always thought mine looked twisted too but they pull out fine and attach properly. Are you having trouble with them while trying to buckle them up??
Old Nov 23, 2022 | 07:35 PM
wannafbody's Avatar
I hardly ever sit over there but it's twisted when I buckle it.
Old Nov 23, 2022 | 08:00 PM
QwkTrip's Avatar
The sheath cannot be flipped because it has a crook in it that needs to face a certain direction. I don't recall if the seat belt itself also has a crooked metal end or if it is straight and can be pulled out of the sheath and flipped. It would be very easy to remove the bolt and see.
The bolt head is a Torx Plus, not a Torx. You could strip the head and have to push really hard to turn the bolt if you use the wrong tool. The bolt turns easy as pie with the right tool. Tighten to 31 lb-ft if I remember right.
