HELP.....water in tail lights
I had one drivers side tail light go bad from water ...so I pulled a tail light off my other car that was in better condition and switched them around....I SILICONED all the seams around the housing .....we had some really heavy rains recently....the reverse light immediately got fogged over ....pulled the tail light out....it was HALF FULL of water....WTF ? did I do a bad seal job or ???????
I could buy a used housing ....but I would have the same problem again
At that rate I’d fully separate them then reseal them. Water must be entering from the top if it’s unable to leak out the bottom.
did you prep the plastic before sealing them with silicone? You Need some auto body solvent before sealing them up.
