Corbeau CR-1s…
Old Sep 25, 2004 | 02:58 PM
bluey2kz28's Avatar
Originally Posted by 2MuchRiceMakesMeSick
Lets see some pictures of the new seats!
As soon as I can borrow a digital camera I will post some pics.
Old Sep 25, 2004 | 03:05 PM
bluey2kz28's Avatar
Originally Posted by John_D.
I would not recommend this for a car without a roll bar. I started to go down this path too. My harness is still not installed.
The problem with a harness, is you are secured too much... If the car rolls (hopefully never, but things happen), then your head is the highest point in the car, and your body is being held firmly in place by the harness.
With stock belts, if the roof crushes, it may still hit your head, but your body can bend to keep your head (and NECK) from taking the full impact. With the harness there is no give...
You do have a point about the harness and the need of a roll bar. A person’s head could get really smashed without the protection of a roll bar or cage setup. I also plan to install a Kenny Brown or similar roll bar in my ride sometime in the future to add to the over safety of the car. What I was referring to was the extra support that the harnesses would give a driver.
Old Sep 26, 2004 | 02:36 PM
2MuchRiceMakesMeSick's Avatar
Cool. I am thinking about getting these exact seats.
Thanks
Old Sep 26, 2004 | 05:16 PM
DONAIMIAN's Avatar
Ive heard of shaving seats in the past, but ive also heard of the seats loosing comfort after being shaved. Since your telling me that its still more comfortable that stock, I think I just might get these in the future.
Old Sep 27, 2004 | 02:56 PM
John_D.'s Avatar
I haven't really noticed anything about the seat bottom, as far as comfort, either better or worse.
The thing I disliked the most about the stock seats, was the curve of the seatback. The top of the seat was between my shoulders and there was no way to settle back into the seat fully, without assuming a hunch-back position...
Old Sep 30, 2004 | 09:14 AM
bluey2kz28's Avatar
I agree with you on those points, but what also bothered me was that every time I took a sharp turn, which is most of the time, I found myself sliding all over the place. This would force me to plant my feet and grab on to the steering wheel to stabilize myself. Like I had stated earlier, these seats give me confidence to hit turns more aggressively without having to worry about swishing all over the place.
Old Sep 30, 2004 | 09:17 AM
bluey2kz28's Avatar
Thanks
By all means, DO IT!
I will try to get a hold of a camera this weekend in order to post some pics.
Old Oct 1, 2004 | 06:17 PM
I have heard that they are much better then stock. The only problem is, im 6' 3" so, im not sure if i can fit from what I have heard, especially with a helmet. Im also looking at these prosports http://www.corbeau.com/products/pros...rosport.shtml#
Old Oct 14, 2004 | 07:19 PM
bluey2kz28's Avatar
I think that the CR-1s will cause you some problems due not to your height, but to design of the seat. They are much better that stock, but they do push our heads up higher or closer to the roofline.
I do not know anything about those prosports or how much closer they will bring you to the roofline. If you are wearing a helmet it might be a problem as well. Try contacting the company to see what kind of problems you might run into.
Even though the seats are not the same model the company may build them in a similar dimension, I honestly do not know. I would research this or any seat extensively before buying a set. Good luck and let us know what you find out.
