spraying clearcoat question?????
I have also been told that could screw up the finish, and that clear is a wet on wet application.
whats true, whats not??????????
I don't do body work, so I can't give you an exact answer, but I do see his point. My guess is with the 1st layer of clear on there he will be wetsanding the car to help level the paint better and remove any imperfections that may have happened. Then after that he will spray it again and possibly re-sand a few areas and finally buff.
by the way, im using all dupont Chroma Premier products.
