Heat shield rattle
The heat shields on the back of the car for the muffler and over the axle pipe are making a noise like no tomorrow. The sound is actually like metal rubbing together, a loud chirping. I know it is the shields because I can put pressure on them and it stops. I have tried everything short of removing them to quiet them down.
Can I actually remove them and not worry or should I leave them and keep fighting the good fight until the noise stops? This is my daily driver so, I don't want things getting too hot back there!
Maybe the shield can be "flexed" with a BFH!
1. find and mark the spot where rubbing is happining
2. remove heat sheild
3. pound the marked spot with a hammer to reshape the spot further away from the spot it is touching
4. test drive
I havent heard a noise since then, good luck
4. test drive
That sounds like a good method. I wouldn't remove any heat shields unless you absolutely had to do so.
You can fix anything with a hammer.
1. find and mark the spot ( on the heat sheild) where rubbing is happining
3. pound the marked spot ( on the heat sheild) with a hammer to reshape the spot further away from the spot it is touching
4. put heat sheild back on
5. test drive
( repeat steps 1-5 it it continues)
5. test drive
