Emblem question
Old Oct 27, 2004 | 12:39 PM
BAKED's Avatar
Default Emblem question
I'm sure this has been asked before, but what is the best way to remove the stock Z-28 emblems so that I can paint them? Thanks.
Old Oct 27, 2004 | 01:29 PM
Trans Am WS6 RGS's Avatar
Use a heat gun (hairdryer) to heat up the glue then take some fishing line and it should come off fairly easy. Then spray some adhesive remover to clean up the glue thats left on your car.
Old Oct 27, 2004 | 01:34 PM
BAKED's Avatar
Killer, the adhesive remover won't harm the paint on the car will it? I'm guessing that I can put them back on with spray adhesive. Thanks.
Old Oct 28, 2004 | 07:09 AM
FirehawkNS's Avatar
Your paint will be fine as long as you clean it all off and make sure to wax the area as the adhesive remover will also remove the wax. I use paint thinner in these situation for years with no troubles!!
Old Oct 28, 2004 | 07:50 AM
David 2002 WS6's Avatar
Lightbulb
We can also use dental floss to break the adhesive keeping emblems on the car.
Old Oct 28, 2004 | 12:24 PM
BAKED's Avatar
thanks for the tips.
Old Nov 9, 2004 | 05:55 PM
craiG's SS's Avatar
Use a heat gun to get the emblem off, then ur u cant get the rest of the 2 sided tape off, u can use an eraser wheel! Works great
