Polished V/C- PITA by hand
Old Jan 17, 2005 | 07:52 PM
Bo White's Avatar
Default Polished V/C- PITA by hand
Not perfect but close enough for me right now lol.
Attached Thumbnails Polished V/C- PITA by hand-ls1-cover-1.jpg   Polished V/C- PITA by hand-ls1-cover-2.jpg   Polished V/C- PITA by hand-ls1-cover-3.jpg
Old Jan 17, 2005 | 07:58 PM
cyphur's Avatar
Bo, good stuff man. Hand polishing isn't the PITA, its the surface prep thats time-consuming and tedious IMHO. I just picked up a water pump to polish....thats gonna be a bitch
Old Jan 17, 2005 | 08:03 PM
Bo White's Avatar
l thought I was crazy 'bout half way through it but a water pump....my God man....have lost your mind lol. Better have some electrical back up . There was about 6 hours or so just prep work by hand sanding. 80 grit, 220, 400, 800, and then 1000. Wet sanded after that and then polished by a 2 stage step I use on my TB blades.
Old Jan 17, 2005 | 08:05 PM
Kurtomac's Avatar
thats looks pretty damn good, considering the shitty pitted metal they use for the valve cover
Old Jan 17, 2005 | 08:08 PM
Bo White's Avatar
I know, sanding all of that crappy casting slag off to get to some decent aluminum took 4ever. Didnt help anything either by doing it all by hand.
Old Jan 17, 2005 | 08:17 PM
cyphur's Avatar
haha....i have a dremel to help with the prep work on the WP. dremel does 80% of the prep work, then hand sanding the rest. i'm going to be trying a two stage polishing deal....maybe some tripoli will help things out lol.
just comin up with ideas
Old Jan 17, 2005 | 08:21 PM
Bo White's Avatar
I use Wenol red and then blue. Great polish.
Old Jan 17, 2005 | 08:39 PM
planemech2's Avatar
I'm in the process of polishing my covers also. Sure is fun getting all the cast marks off. I also polished my fuel rail. Much easier.
Old Jan 18, 2005 | 09:33 AM
Bo White's Avatar
Once you get all of the casting crud cut off its just prep work from there on out. Wet sand only to slick it out not to cut any material off, dry sand up to that point.
Old Jan 18, 2005 | 06:55 PM
Physics's Avatar
It looks great. Yeah, it's a pain to get the casting material off, especially if it's really pitted. I'm in the process of polishing my LT1 intake manifold, and it's pretty tough, even with my Dremel.
Old Jan 19, 2005 | 06:32 AM
JackZ28's Avatar
I did mine too, and it was indeed a HUGE PITA! Yours look very good though! Nice work!
