What color calipers.....
Old Jan 28, 2005 | 03:08 PM
JxxxOxxxE's Avatar
Here is what I had posted before...
Well, in a quick rundown. I dremel with 60 grit, then use a die grinder with a 3 inch sanding pad at 280 grit, then hand wet sand with 400 grit, hand wet sand with 600 grit, and hand wet sand with 1500 grit. Then I apply tripoli compound with my dremel, with a cotton wheel on there. The caliper face should start turning kinda black, you will be able to see it. Then I use a cotton rag with some mothers mag polish and polish the tripoli away by hand. Then wipe clean with another rag. Sometimes I tripoli a few times to get it good....
Old Jan 28, 2005 | 03:32 PM
BTLFEDSS's Avatar
Yup Jantzer is the sponsor JxxxOxxxE car looks tough with the prostars
BTLFEDSS
