Camaro LED Tail Lights
Old Feb 3, 2005 | 07:44 AM
  #41
LS1_SS's Avatar
Ive though about it but its too ricey to me, no offense, what year prelude?? I made them for my old 94 prelude, they were great!
Old Feb 3, 2005 | 07:45 AM
  #42
InfiniteReality's Avatar
Originally Posted by LSWannabe
They look great. Have you ever thought about arranging the LEDs in a bowtie outline, and then when the brake is applied have the bowtie entirely filled or something. I dont know if it's possible to do but I think it would sell great.
That's a sweet idea. Or do the inverse of it... How cool would that be? 300+ per side gonna be hella bright! I'd like to see how you got the lenses to all seal up, but I think that's probably a trade secret....
Old Feb 3, 2005 | 08:33 AM
  #43
LS1_SS's Avatar
This ones going to be tricky, the lenses are completely open so I'm gonna have to figure somethin out.
Old Feb 3, 2005 | 10:22 AM
  #44
karkrazie626's Avatar
Doe the turn signals have LED's as well? That would be a big plus!!!
Old Feb 3, 2005 | 01:44 PM
  #45
LS1_SS's Avatar
The ones Im doing now will have orange leds in the turn signals, but when theyre off theyres clear so you dont even notice them, also the reverse lights will be LEDs
Old Feb 3, 2005 | 03:13 PM
  #46
LSWannabe's Avatar
You could do the bowtie in a lower profile. Make it much wider and not as tall. Cut down on the riceyness. I agree if it was not done right it wouldnt look good.
Old Feb 3, 2005 | 10:19 PM
  #47
MasterOfPuppets's Avatar
Originally Posted by LS1_SS
http://www.cardomain.com/id/ls1_ss
Theres pics of the first set on that site..
I was thinking of doing the same thing, but I don't know that much about LED's. From what I can see...The driving lights are the lower row and when you hit the brakes the top smaller row lights up? Am I right? Or do the lower running lights light up brighter with the top brake lights on too? How is the heat from the rear of the taillights and How did you seal them so water or dirt can't get in? Are they plug and play too? Thanks for your time and for any info.
Old Feb 3, 2005 | 10:23 PM
  #48
LS1_SS's Avatar
yes your right... actually believe it or not leds give off little or no heat, compared to lights theyre nothing.... the sealing is a pain in the a$$... its pretty complicated... and no theyre not plug and play, its lots of tideous work, lots of soldering.. when Im done all you have to do is wire them up, takes 5 mins and your good to go.... I honestly wouldnt reccommend doing them unless you know a pretty good amount about leds... I didnt know crap when I first started, Ive gone mostly on the try and fail method and just figured it out as I go, but I have learned a lot since then so Im pretty good at it now.....
Old Feb 4, 2005 | 06:17 AM
  #49
willis 00's Avatar
its a 01 prelude. too ricey?? ok but a taillight is a taillight ricey or not. i thought you want to make some money, you look like you do good work. just so you know its not some tacked up import. its clean,stock electron blue with TL type-s wheels. i have a hid conversion but would love to do a custom set of led tails to round it out. i love advanced lighting it really gives a car a modern upscale look.
Old Feb 4, 2005 | 11:37 AM
  #50
LS1_SS's Avatar
I was talking about the chevy bowtie being ricey, can you get me an extra set of tail lights cheap? I would have to get a set you dont need just in case I cant fix them.
Old Feb 4, 2005 | 02:42 PM
  #51
brandonppr's Avatar
I found this site it has some diagrams on leds.
http://www.lastofthebreed.com/Instal...rdLEDCargo.htm
also I beleive you can control the brightness with resistors and make it where when the running lights are on they are all on but dim then when brakes are on they all get bright.
Old Feb 4, 2005 | 04:06 PM
  #52
willis 00's Avatar
oh,my bad iam just used to a lot of people on here thinking all hondas are ricey. ill have to look around for some. i dont use the car everyday so i would just send you mine,but it would be better to have a second set just in case. ill start searching around.
Old Feb 4, 2005 | 04:08 PM
  #53
Blade's Avatar
I love the look of the hyper whites in the interior.
Old Feb 4, 2005 | 07:16 PM
  #54
Ws6Extreme's Avatar
Wrong Place.
Old Feb 5, 2005 | 12:02 PM
  #55
LS1_SS's Avatar
Ok the first light is almost done, im just waiting to get the resistors... ends up being almost 250 leds per light... theyre gonna be bright!
Old Feb 5, 2005 | 12:14 PM
  #56
BTLFEDSS's Avatar
PICS
BTLFEDSS
Old Feb 5, 2005 | 12:20 PM
  #57
LS1_SS's Avatar
I cant finish them until I get the resistors.... Ill have a few by the end of the week.. I hope!
Old Feb 9, 2005 | 12:21 AM
  #58
keep the pics coming!
Old Feb 9, 2005 | 07:12 AM
  #59
JasonWW's Avatar
LS1_SS, why are you using resistors? If you are wiring them in a parallel/series configuration, you shouldn't need any.
Can you explain how you are using the resistors?
Old Feb 9, 2005 | 09:56 AM
  #60
LS1_SS's Avatar
Yes you wont need any, but what happens when your voltage just jolts up for no reason? there goes all your hard work, its much safer to have them, even if there absolutly nothing like im using 56 ohm just to be safe....
