T-top help
http://tinypic.com/view.html?pic=1opy00
http://tinypic.com/view.html?pic=1opy50
As you should be able to see, it fits perfectly on the outside, but doesn't at all from the inside
It doesn't leak or anything, it just sounds and looks like it is going to fly off!!
Thanks!!
-Todd
Take the 2 screws out of the rear trim piece cover and the bracket is held by 2 13mm bolts I believe...
you can move it forward/backwards and shim it up and(maybe down) to adjust it right. May not be anysort of body flex just a misaligned t-top. They were made to be moved around since no 2 cars were going to be 100% identical.
