Fog lights?
Thanx
Josh
You can find them pretty cheap on ebay too.
Check out sylvania silverstars either 894 or 893ST.
The 894 is the direct replacement right angle bulb assy.
The 893ST is a straight (not a right angle) but fits just fine.
Good luck.
It is just a suggestion if you are interested.
I bought a cheap set of blazertech 3200 fog lamps and they came with a metal housing. I replaced the bulbs with dirt cheap 100watt bulbs and they were extremely better than stock. Obviously, the light intensity on the ground wont cover a large area (dont expect headlamp lighting) since the fogs are mounted deep inside the bumper, BUT, you'd be suprised how much better it could be with 100watt bulbs.
Unfortunately my cheap $10 bulb (or probably cheaper) didnt last longer than 4 months. Im looking for something with better quality to last longer. If I dont find anything ill go back to the cheap 100watt bulbs.
Is there any good company that makes good high wattage bulbs?
The PIAA 1100x is great but its not something i'd mount in my bumper. The diameter of the lens is too small in comparison to the stock fog lens. Also its kinda ricer looking too if you ask me.. pic attached.
As for the sylvanias they are both 37.5 Watts... I tried that wattage on a different brand bulb and the fogs looked as if they were stuck in the grey area between appearing "cosmetic" and actually "being bright enough" (for me atleast) - if you know what I mean.
link:
http://www.cartoys.com/cartoys/showd...oduct_ID/40172
