Body Pulling off of frame?
Old Mar 24, 2005 | 09:38 PM
Tritonium's Avatar
Default Body Pulling off of frame?
Fellow F Bodyites,
I have a slight problem with my baby, i dont have pictures of it and it is dark out so bear with my explaination. The drivers door, when i try to open the door when the car is locked the body acctully pulls away from the door frame; when away from the frame, it seems as if a white bead of glue is there (on the door frame that adhears to the body), apparantly, it failed. Does anyone have a suggestion on what type of glue that is, or any other ideas.(No Rivits ) Thank you!
Old Mar 25, 2005 | 12:11 AM
00SilverWS6's Avatar
Is it just the door skin coming unglued from the actual door? If so jsut use Fiberglass resin.
Old Mar 25, 2005 | 01:56 PM
fasteddyss's Avatar
Go to an auto body supply store ang get the right glue. The doors and frames are made out of SMC(sheet molded compound), not fiberglass.
Good luck
Old Mar 25, 2005 | 05:01 PM
Tritonium's Avatar
thanks guys!
