Blinkers not working!!!
Old Apr 2, 2005 | 03:32 PM
neonblack's Avatar
Default Blinkers not working!!!
Ok, I just installed some LEDs for the parking and turn signal lights. They both come on when i turn on the parking lights, but they don't work when i flip the turn signal lever (neither do the rear ones). The green arrow on the dash lights up, so i assume the fuses are ok.
Anyone have any ideas? Thanks!
Old Apr 2, 2005 | 03:35 PM
1998TA__1991RS's Avatar
u need an electronic flasher unit should be an el12
Old Apr 2, 2005 | 03:58 PM
neonblack's Avatar
Thanks. Is that located in the main fuse panel on the end of the dash on the drivers side?
Old Apr 2, 2005 | 10:42 PM
should be under the dash but dont take my word on it
Old Apr 2, 2005 | 10:45 PM
VIP1's Avatar
Copy & Paste Moderator
Its hidden behind the shin panel under the steering wheel. You need two electonic flashers (Trident EL-12, I think). One is for the signals (left & right), the other is for the hazards.
https://ls1tech.com/forums/showthrea...ghlight=signal
https://ls1tech.com/forums/showthrea...ighlight=flash
